Fanatical Meat
I have a 2012 sonic, the right headlight keep blowing out. This will be the third change in 24 months. The light is in a sealed compartment and always looks clean when removed.
I do not touch the bulb, I do not use lithium(?) grease. I have been buying cheaper brand name bulbs.
Should I use the grease stuff? I don’t like it because it makes a mess and from the factory it didn’t have any
Are lower cost brand name lights that much worse than higher cost?
Have I simply had bad luck?
