Headless problem.
unbiased
380
If a person's head is cut off at the guillotine, will the pain be sensed by the head or the body?
If at the same instance his leg is also cut off then this will be sensed by which part?
lxskllr
60,964
11,297
Hell of a necro. My guess is the only feeling would be in your head. If your head lived long enough, and saw the leg being cut, it would feel the pain because it was expected. Would be an interesting way to die in any case.
CZroe
24,195
857
I don't know about you guys, but each of my limbs and my torso are all self-aware.
Charmonium
10,654
3,610
Headless means you haven't gotten head for a very long time. Headlessness isn't usually fatal but can be in some cases.
DaveSimmons
40,730
670
Any pain felt by the head would be psychosomatic since the nerves connecting it to the body have been severed. If you severed the head and then punched it in the nose it could feel that.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
I don't think it's a necro if the OP bumps his own post. He just never got his question answered.
Carson Dyle
8,173
524
ATOT is certainly the first place I'd think to look for such answers.
Exactly how long a person can remain conscious after decapitation remains debatable. We know that chickens often walk around for several seconds after decapitation; the Dutch rat study mentioned earlier suggests a length of perhaps four seconds. Other studies of small mammals have found up to 29 seconds
Most recently, in 1989, an Army veteran reported that following a car accident that he was in with a friend, the decapitated head of his friend changed facial expressions: "First of shock or confusion then to terror or grief,"
I'll bet that memory would keep you up at night for a little while.
http://science.howstuffworks.com/science-vs-myth/extrasensory-perceptions/lucid-decapitation3.htm
Azraele
16,524
29
Bump. After ten years
Long wait for an answer. Now that's patience. :)
I do not know the answer to your question, however. But I can say this. Have you ever accidentally cut yourself, and know you were cut, but it takes a few seconds for the pain to register? You'd die so quickly if your head were severed, you may not feel a thing.
WHAMPOM
7,628
183
Ask anyone that has had a major injury, shock first, pain comes later. "Why is my hand bleeding and where did the fingers go?"
RelaxTheMind
2,245
i thought this was going to be a headless server question.
in response to the OP. I remember this being discussed in class in HS, there were supposedly being tests done with the severed heads and found the brain was still active and responsive for a few seconds after being detached. I remember there being a specific person that did unorthodox studies but cant remember. probably a handful of lengthy papers about it nowadays.
