The head gasket blew up on my car nearly a week ago. As the car wasn't worth taking to the garage to get fixed ('88 Dodge Shadow), I decided to change it myself. After going through hell trying to take off the manifolds (a few of the bolts were just about impossible to reach), I decided to just disconnect the exhaust pipe and take out the head with the manifolds attached.
Well, that didn't go so well either. I took off one of the exhaust pipe bolts, but the other one won't come off, I can't use a wrench to take it off because the bolts are too stripped, and I can't use a ratchet because there's not enough room around the bolts to put the ratchet on (I used a ratchet on the other side). I tried to saw the bolt off, but after 1/2 hour of sawing in that inaccessible location I only scratched the bolt (and the metal bracket below it)! I'm really pissed off now, that one bolt is keeping me from pulling the head off but I can't remove it! Any suggestions on what else I could do?
Edit: I've used WD-40, Screwloose, and some other crap on the bolt but none of that worked. It's simply too rusted. Oh, I'm not so sure I have a blowtorch here, either
