- May 19, 2011
- 21,260
- 16,502
- 136
A disk I was taking a look at today was doing the classic beepy/clicky noise that people here are probably familiar with when hard drives have gone to heaven or have undergone a near-death experience
The head was stuck on the platter, and I used the technique I've mentioned previously to retrieve the stuck head from the platter and park it manually, however I also noticed some loose fragments.
The fragments are paper-thin, both are about 1mm square and are highly reflective but dark in colour. I doubt that I could get a decent picture of them to post.
As one might expect after finding visible debris inside the drive, of course the drive hasn't worked. Sometimes the heads would have a little fit when the drive was powered, sometimes not. The platter has spun on every occasion when powering it up.
I can move the heads without any problem across the platter (when the drive is off).
Unless anyone has any bright ideas for recovering data from this drive (the data isn't worth enough to justify the big-name data recovery companies), I'm inclined to pronounce it dead and move on, I was just curious about what these fragments might be in case anyone here is intimately familiar with the innards of hard drives.
