I've been hinting around the forums about questions here and there and finally decided I'd just compile all of my questions together into one post - figure I'd get more opinions this way. So here goes...
I'm looking to build a HTPC to run beside my DirecTV unit (has no DVR or HD) mostly because I'd like to get HD over the air. Right now I have an ATI HDTV Wonder that I'm going to take back because it sucks. I also have an Antec NSK2400 which I think I want to stick with so I'm limited to uATX stuff but I don't see this as a problem.
So anyways, let's just go through all of the key features...
CPU:
I assume 2GHz AMD64 is sufficient for anything I'd need, even in HD?
Mobo:
Something to accomodate the CPU and video card, blah blah...
RAM:
I wouldn't go with less than 1GB, probably use 1.5-2.
Video Card:
I currently have a 6800 OC that I plan on using - is this overkill? I assume this is plenty powerful enough. I don't plan on doing any gaming at all.
TV Tuner:
I need suggestions for this please! Like I said before, I'd like to only use it for HD OTA and I think I'd like to have 2 tuners (to record one thing while watching another). It wouldn't be horrible if there was another input I could use to hook my DirecTV to just in case I wanted to use it as a DVR for DirecTV content. Also, in case it matters, my HDTV signals here are relatively weak. I really have to fidget with the antenna to get a strong signal so if one tuner is much better than another with picking up good signals, please keep that in mind.
Antenna:
I currently have a Newpoint Argo XP 208230 antenna that I may or may not take back to the store depending on what you all recommend. I'd like a budget antenna here ($50 or less) and something that's not huge. It's going to be in my garage on top of some shelving on the walls. Again, DTV is all I care about - don't give a damn about analog if that matters on this one.
Software:
I run Windows so I'm planning on either SageTV or BeyondTV. It seems like BTV has more numbers but I've heard better arguments for Sage. I'll probalby end up installing them both and trying to figure out which one I like best. But please give me your opinions on this as well!
Anything else I'm forgetting??
Let's see, I'm hooking this up to a 40" Sony Bravia 720p LCD, my case has it's PSU built in, I'd like to have a remote with whatever I get so if the tuner you recommend doesn't come with a remote, please have a solution for that. I'd like to ideally never have to use the kb/mouse unless I'm changing something with the system's setup (updating drivers, etc.). Please let me know if I'm forgetting something important. Oh yeah, am just using onboard sound and got my USB wifi card (good old $10 Airlink from Fry's
Thanks in advance!!
-Jax
CPU:
Mobo:
RAM:
Video Card:
TV Tuner:
Antenna:
Software:
Thanks in advance!!
-Jax
