HDTV cables and quality
RaMz121
which one of these situations would make hdtv better
dvi from cable box to tv's hdmi input
rgb from cable to rgb tv input
dvi from cable box to tv's hd15 input
I only have one hdmi on my tv and i need one of those options for my tv and another for when i get xbox360 or ps3
It actually depends on the tv. Some look better using a digital input and some look better with an analog input.
I'd suggest going over to AVSforum and looking up your specific model.
That won't work at all so you can rule it out (HD-15 = VGA analog) You may have to get a switcher if you need multiple digital inputs if the RGB gets downconverted down the road.
dvi from cable box to tv's hdmi input = BEST
rgb from cable to rgb tv input = Next Best (RGB is actually analog)
dvi from cable box to tv's hd15 input (DVI is digital and HD15 is analog) Like rbv5 stated it Wont Work.
If you need cheap great quality cable I suggest:
http://www.bluejeanscable.com/
You can also learn a lot about cables on his site. Very honest guy too. I mistakenly ordered cables and they were sent to my old address. I requested when they returned to him he send them and bill me the extra shipping. He sent me replacements before he ever got the cables back for my own stupidity.
