- Dec 6, 2001
- 8,361
- 1
- 0
what I'm trying to accomplish:
I want to get local channels in HD only (I really just need abc, nbc, fox, cbs, and maybe tbs but it won't hurt my feelings if I can't get tbs...). I don't realy care about getting HBO or any DVR/on demand features. I also don't want a set top box, I'd rather just plug a coax cable and a power cable to my wall mounted tv only. I don't want to mess with any more cables coming from the cable box...
with that my only option is to get an HDTV with a cablecard slot right? if so, then I have a few questions...
1. I know the cablecard plugs into the pcmcia cablecard slot. does anything plug into the cablecard itself? if not, where does the signal come in? through the regular coax cable? once the signal comes through the regular coax cable, then it is decrypted by the cable card right? Just wondering how many cables need to go to the back of the tv...
2. cablecard v1 vs v2. obviously if you can get an HDTV with v2 slot, get it. but I need some recommendations. is v2 slot capable tv's even out yet? how can you tell if it's v1 or v2?
3. I'm going with comcast and I just called them. I explained what I wanted and the rep. said this is possible with just the basic package @ $16.95 plus $6.95 for the HD. Does anyone have comcast who can confirm this? how is the quality? does it still give you the occasional stutter like HDTV OVA? I'm looking more for the stability that regular cable tv provides. If comcast HD via cable card does not provide this, then I would not be interested...
thanks for you input.
