- Jun 24, 2003
- 29,582
- 12
- 76
I did a search for HDTV, and sorted through about 100 threads, but I really didn't find too much info... I have a Radeon 9800 Pro... If I were to go out and buy say, a Samsung TXN3298HF which has component inputs, as well as DVI, could I just plug my DVI right into it? Would that be the best way to do it? Or would component input be better?
What resolution does an HDTV display natively? Can an HDTV change resolutions, or is it set at one resolution? Would games look ok on a 27" or 30" HDTV?
