hdtv antenna
Nithin
961
I got an the sceptre hdtv from costco with atsc/qam tuners.
i want to give OTA channels a shot before i subscribe to cable.
any recommendations on which antenna to buy?
thanks,
Nithin.
nakedfrog
63,293
19,653
Use antennaweb.org to figure out if you need an amplified antenna, and if so, how much amplification you need.
mattg1981
957
I use a terk tv5 and it works amazing ... I get channels that even antennaweb.org says I shouldnt get. It doesnt look as nice in person as it does in pictures though ... the thing is fugly and hard hide
nakedfrog
63,293
19,653
Yeah, antennaweb does seem a little pessimistic, it said I should use a medium outdoor antenna (I forget the color).
I bought a Philips "HDTV" indoor antenna with a 50 dB amp, and get all the channels antennaweb shows, most of the time. The NBC and PBS signals are a little tricky.
Ramma2
2,710
I picked up a channel master 4228 I think, it hangs in the rafters in my garage. Very good signal strength from 27 miles out, ranges from 88% to 95%.
FreshPrince
8,361
how do you get PBS to work?
I have not figured that part out yet... :(
HN
8,186
4
I have a Terk HDTVi. It is similar to the zenith/phillips silver sensor except the terk also has telescoping antennas for VHF. works very well.
HD gear so far:
OnAir HDTV GT (usb hd tuner)
Terk HDTVi antenna for OTA and cable for unencrypted QAM (but the OTA stuff is MUCH better for me)
dell 2405 fpw monitor
I need a bigger hdd now :eek:
Nithin
961
how far are you guys from the transmitters? according to antennaweb i'm about 30 miles away. can i expect a good signal?
my zip is 91304, canoga park, california
mattg1981
957
I think 30 miles is right on the edge of how far the signal will travel ... it may be real hit and miss for ya
nakedfrog
63,293
19,653
I just have to have the antenna pointed just right... even then it's kinda spotty. I did get to watch part of the New York Dolls on Soundstage in HD a few weeks ago, though.
nakedfrog
63,293
19,653
I'm about 22 miles away, but I'm also at the top of a hill.
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
Yep. Even at 15-22 miles with an outdoor roof-mounted antenna, I'm still hit and miss. Especially with NBC for some reason.
edro
24,326
68
I got a Philips $10 silver one and it works great. I am in the city though.
