Interesting post from 'someone who knows': Dave Baumann
Link to beyond3d forum
Seems like to big bom still has to fall...
Hi guys,
OK, I've only just got back home in the UK from Shader day and am beginning to catch up on the aftermath of Gabes statements.
I've not read all this thread so I don't know if this has been mentioned before, but I see that NVIDIA are suggesting using PS1.4 for many effects and there will be limited visual difference. There is a problem with this though.
Whilst Valve were there they displayed that they had implemented higher dynamic range into the engine. HDR will be available in the game to those that support its requirements, however it is not currently implemented in the benchmark. HDR needs the a higher range, and PS1.4 only has -8, 8 range which is probably not enough - the HDR effects also require float buffers which none of the current NVIDIA drivers support. There is also dramatic visual differences between HDR being enabled and disabled.
HDR is currently not in the benchmark mode because NVIDIA don't support float buffers at the moment and the benchmark was designed to render equally on all systems.
