HDMI or DVI? for connection to TV
calvin0416
90
For this TV. It says it has 1 PC input but I'm not sure if it's DVI or VGA. Couldn't find pictures of it's input on google.
What's the best way to connect your computer to the TV?
calvin0416
90
I read somewhere HDMI also does sound. So if I connect my GPU to my TV via HDMI, it will have sound??
NoQuarter
1,006
Depends on your GPU but the last 4 or 5 generations of video cards have all carried sound over HDMI (even if you have to use a DVI->HDMI adapter). Makes using HDMI the most convenient way to hook your PC up to TV if you are planning on using audio over the HDMI.
Quality wise there is no difference between HDMI or DVI but VGA is inferior.
Monoprice.com is also a really good place for cables and adapters.
