- Dec 12, 2001
- 27,052
- 357
- 126
I have been reading that on most (all?) HDTVs that use HDMI that you cannot use HDMI in to the TV from a source such as an HD Cable box and get 5.1 surround out via the optical port. Is this true? If so what is the way around this limitation? Go out from the HD Cable box to a Receiver's HDMI in to process the sound and pass the video through to the TV?
I guess the simple solution is to use the Coax out from the box in to the TV and the optical out to the receiver. Kinda defeats the point of HDMI that way.
Do I have this all correct? Just found this while reading some HDTV reviews.
In short is the best way to go as follows?: HD Cable via HDMI out to the receiver and then out to the TV?
edit: obviously 1080p is not going to be necessary in this case so the quality between coax/component/hdmi should be very minor no?
