I am currently looking into buying a display for my new build and i want to get a 4K display.
After waiting and waiting the new 4k monitors started showing up in my country as well. However i recently found a sale on Samsung 4k TV's with HDMI 2.0.
After reading around a bit i found a mention on Anandtech that the HU6900 series even with HDMI 2.0 does not support 4:4:4 format but nstead has 4:2:0 which basically is what NVIDIA is using to get 4k at 60 Hz on HDMI 1.4.
I looked at the specs for HDMI 2.0 and found this
What are the 4K formats supported by HDMI 2.0?
4K@60
8BIT - RGB,4:4:4,4:2:0
10BIT - 4:2:0
12BIT - 4:2:2,4:2:0
16BIT - 4:2:0
I assume the 40HU6900 Tv has an IPS panel which should be 10bit but i can't find and info on this anyone know?
Also why can HDMI 2.0 do 4:2:2 at 12 bit but only 4:2:0 at 10?
I am not very familiar with the chroma subsampling technique but could someone help me decide on a display?
Below are the specs i am taking into account for each display:
Asus PB287Q: TN panel, 8bit + 2 bit dithering, 1ms response time, DP1.2 which i think has 4:4:4 at 4k 60Hz (can anyone confirm?), portrait mode for future surround
Samsung 40HU6900: IPS (?), 10bit (?), 8ms response time (just guessing, 8ms is the norm for IPS from what i know), HDMI 2.0 which either has 4:4:4 or 4:2:0, also needed a TV as i did not have one, BIG but not too big
I would love to get the Samsung TV but i don't know how bad it is at 4k using HDMI 2.0 (will probably ask them what they support exactly from HDMI 2.0 before buying) compared to the 8+2 bit but with full 4:4:4 support at 60Hz that the Asus has.
I know i would be limited to HDMI 1.4 until an active adaptor for dp1.2 to hdmi 2.0 comes out but if the display is worth it i could wait but which ones is better?
I don't know how big of a difference is between 4:4:4 and 4:2:0 at 4k and how that compares on a 10bit IPS display versus an 8bit+2bit TN.
Also i found this review of the TV but not sure how trustworthy it is that says it has full 4:4:4 support
Full 4:4:4 reproduction (PC) Yes, with [PC] input label
Note that i will be mainly gaming on the display with work and movies on the side.
4K@60
10BIT - 4:2:0
12BIT - 4:2:2,4:2:0
16BIT - 4:2:0
