- Feb 5, 2009
- 49
- 0
- 0
Hi Atech forums
Let's say we have two HDD's and there's an OS in each one (it could be the same OS doesn't matter). We are running a heavy program in which timing and access speed is important, a game fits this criteria perfectly.
So what is better:
1-) Use the OS in one hard disk and install the game in the other.
or
2-)Install the game in the same drive the OS is held.
The other important factor, i imagine, is if the 2 HD's are the same or different. Let's assume both cases.
Hope i can get some answers for the above ideal cases. As for my reality, one HD is a WD green, as you probably know, it mostly speens at 5400 RPM. The other is an old Maxtor 160 GB drive, which i asume spins at 7200 RPM. What´s the best way to install a program according to the answer related to the above cases?
Thanks for any answers or recomendations.
So what is better:
or
