Hi folks,
have a bit of a problem with one of my drives so I hope someone here will be able to help me.
Here's the thing:
I have 4 drives in my PC as my main drives.
I bought a new 1TB drive and enclosure to use as a backup drive. I have a Gigabyte P35-DS3P mobo and I use Thermaltake Max 4 enclosure. I have the drive connected with eSATA. Everything went ok, all good. I get 935GB of space, and drive works great. So few days ago, I backed up some stuff on this drive and today I started to rebuild my OS on one of my main 4 drives. I got XP Pro up and running, I connected the 1TB external drive, XP found it and I moved a bit of stuff of it. Then I wen to Windows Update and started to update XP. First (and only) update was SP3. After it installed it, it rebooted (have to note here, my 1TB was ON when I rebooted).
After the sistem got up, problems with 1TB drive started. First of all XP doesn't find it, I have to use Find New Hardware wizard. Then it does find it BUT, I get only a letter (used to have a full label) AND it shows it as 32MB drive and when I click on it, it says drive is not formated and wants it to format.
I connected the drive to my laptop, same thing. 32MB, not formatted.
So I installed TestDisk, ran it (took almost an hour), and got status:
Boot sector
Status: OK
Backup boot sector
ntfs_boot_sector: Can't read backup boot sector
Status: BAD
Sectors are not identical.
I then tried the "ORG BS" option (Copy boot sector over backup sector)
and get the error:
Write error: Can't overwrite NTFS backup boot sector.
I did notice before, it warned that correct drive size must be reported or recovery wont work. So no wonder it doesn't work.
So now I'm lost. What can I do? I have important stuff on the drive and REALLY don't want to re-format it. Why 32MB size, what happened?
Pls help!
TIA,
Mat
Update #1:
I played around with TestDisk a bit, got following status:
The harddisk (33MB) seems too small!! << 1000 GB / 931 GiB >>
Check the harddisk size: HD jumpers settings, BIOS detection...
Hint: update Windows to support LBA48 (minimum: W2K SP4 or XP SP1)
The following partitions can't be recovered
HPFS - NTFS ........
So I'm guessing, partition is there, but it's somehow hidden. (BTW: one other status from TestDrive said: "no boot partition present")
I didn't change jumpers/bios during XP SP1 - SP3 upgrade, so the drive should work as it did before, but it doesn't.
Here's the thing:
Boot sector
Status: OK
Backup boot sector
Status: BAD
and get the error:
Pls help!
TIA,
Mat
Update #1:
