- May 6, 2004
- 6,285
- 1
- 0
A friend of mine had his toshiba-branded hdd die on him, and luckily for him I happened to have a 2.5'' fujitsu sitting around from a now deceased laptop of my own. The trouble came when we tried to put the damn thing into the drive slot with the drive cage on, it simply wouldnt slide in.
Upon more careful inspection, the left corner of the dysfunctional toshiba drive has a diagonal indentation absent from the fujitsu; inside the drive bay, there is a protruding area that matches with indentation, which obviously conflicts with the drive that lacks a matching structure.
The fujitsu drive appears to be quite standard, so it must be some sort of proprietary thing for this satellite lineup. Since it is more of piece of plastic sticking out than missing, I doubt there would be some kind of simple adapter solution of any sort. Does it require some sort of drive specially made for this computer? Or maybe I could open up the laptop and remove some unnecessary bits of plastic to sort it out?
