HDCP Compliant vid card + Blue Ray ROM + Component output = DRM HEll BOOOOOOooooOOoo!!!ooooOOOoO!!!oOOOO
Qianglong
937
So if i get a BlueRay Rom for my HTPC and it is hooked up to my RPTV that only supports 1080i, will the movies be downgraded to 480p?
Auric
9,591
Software can bypass all the anti-user schemes. But even in lieu of that, 1080i analog remains possible with existing content. In a few years, discs may be published with Image Constraint Token to restrict such output to 540p.
P.S. it's "Blu-ray Disc" or "BD" for short. BD-ROM is inferred.
Saga
Banned
Feb 18, 2005
2,718
So we lose HD-DVD just to gain Sony's forced DRM and limitations?
cubby1223
13,518
42
86
Both formats have the same HDCP requirements. :roll:
On a computer, you must use a dvi or hdmi connection to an hdcp monitor or tv.
Auric
9,591
But clearly one multinational conglomerate and associates are e-vil whilst the other multinational conglomerate and largely the same associates are goodness and light.
