Well if what you are saying is in fact true, then NV is toast for at least 3 months.
Looks like another awesome launch by AMD to look forward to.
Well, it remains to be seen how these new parts will be priced. =p
I thought that was already factored in, hence the 4D-is-95%-as-fast-as-5D thing. If that wasn't factored in, then I suppose it is indeed possible for Barts XT to match Cypress XT without having to be clocked at 1GHz+
I always interpreted the "easier to feed" aspect of the 4D cluster implying that its practical performance might actually outstrip the practical performance of the 5D cluster, despite its theoretical peak output dropping.
For example, say the 5D's peak performance is 1, while the 4D's peak performance is 90% of the 5D's peak or 0.9. In the real world however, the 5D arch can only extract 50% or .5 of its theoretical peak while the 4D arch can hit 75% or .75 of its theoretical peak output.
5D cluster's practical output would be 1 x .5 = .5 = 50% of 5D peak
4D cluster's practical output would be .9 x .75 = .675 = 67.5% of 5D peak
So in the given scenario, despite the 4D cluster's 10% lower theoretical peak it would actually outperform the 5D cluster by 17.5% in real world applications.
Unless I horribly failed at basic maths or my logic is horribly broken it could be possible for the Barts XT in any incarnation to turn out extremely powerful, let alone Cayman XT.
That being said, I do think the hype for the 6xxx series is getting a little out of hand and people should really par down expectations. This is a refresh on the same node, so room for improvement is a little limited.
Dang I had just edited my inquiry a moment before you posted this, too, after I answered my own questions: Ah never mind, I am reading at S|A about efficiency improvements all around. Seems like every little bit adds up to a nice speed bump, plus the smaller 4D shaders allow more to be packed into the same die area. One of the posters there who has historically had some degree of accuracy says that Barts XT will be in-between HD5870 and HD5850 in performance but didn't say which one it would be closer to.
Yes the setup and triangle rates are reportedly improved. Also the shaders at 1280 would be a very nice bump up from the 800 shaders of Juniper, made possible by the 4D architecture shift. Possible clockspeed bump up, too, as yields have improved on 40nm.
I don't know if there is that much hype on the HD6xxx series, it's expected to be 30-50% faster than HD5xxx which is perfectly reasonable on a somewhat larger die + various uncore efficiencies + new shaders + clockspeed bump + reclaiming some unused die space from the Cypress layout and/or removing now-unneeded redundancies.
Personally it all boils down to pricing now for me. If AMD screws up pricing, it won't matter how well their chips perform.
There's a rumor that the 2+2 setup no longer has all simple SPs, but all four are medium. So you end up with 1/2 DP performance as 2 SPs combined to process DP, rather than 1/5 in evergreen (~2.7 Tflops sp, ~500 Gflops dp). But if it's true, Cayman XT may have >1 Tflops DP. That would be insane.
I can't confirm this leak though.
If that were true, there would be no point in the 2+2 nomenclature. 2+2 indicates there are differences. Else it would just be 4. Unless of course the 2+2 leak was bogus.
