ender11122
So I am building a water cooled setup and was in the market for a reference 6970. After doing a little egg hunting I came across this:
http://www.newegg.com/Product/Produc...-356-_-Product
Has all the hallmarks of a reference design; AMD logo on the slot, backplate and bios switches. Unfortunately when i received it, it is a completely non-reference card. No backplate, no bios switch, not even same components on the PCB. Apparently HIS made a revision to the card using a non-standard design. When doing so, they continue to use the same model number that the original reference design used.
Cliff notes, HIS H697F2G2M is NOT an AMD reference design, no matter what HIS website tells you.
PART 2:
After research, it turns out XFX is pulling the same stunt.
http://www.newegg.com/Product/Produc...-517-_-Product
The only way to tell is when you actually get the card it is obviously not the reference card, but they justify it by adding V1.1 to the model sticker on the card itself, but nowhere else.
PART 2:
