Hello chaps,
Specs:
Intel e8400 @3.8ghz
Asus P5Q-E
4GB DDR2 1066 OCZ Ram
MSI Radeon HD6950
Windows XP 32 bit (don't mention it, 7 is in the post lol).
Samsung 2233rz
Thanks for reading.
I've just moved from a 8800GTS G92 to a HD6950 and so far so good... but.... heres the thing.
I can run 120hz on the desktop res of 1680x1050 with no problems.
I can run Call of Duty 4 in game at 120hz on any resolution APART from 1680x1050.
For some reason the monitor/gpu in game at 1680x1050 forces itself to 60hz.
Whether its the gpu, monitor, software... I can't figure it out.
I've set 3d refresh override to 120hz, default, disabled. Fiddled around with the monitor (limited settings honestly), swapped config because I ran out of ideas too - still nothing.
120hz at every res APART from the supposed 'native' res. All after changing card. This was working fine with my old 8800gts g92.
I've installed the latest catalyst drivers and tried the MSI catalyst drivers that came with the card too, no luck
Any ideas?
Thanks,
Bob
Specs:
Intel e8400 @3.8ghz
Asus P5Q-E
MSI Radeon HD6950
Samsung 2233rz
Thanks for reading.
Any ideas?
Thanks,
Bob
