I currently have
MSI K9A2 neo -f mobo
AMD Phenom II x4 940 BE
4 gigs Patriot ddr2
sound blaster audigy 2 zs
evga 8800 gt 512mb
Silverstone element 500 watt psu (two 12v rails, 18 on each for total 36 amps) this is 3 years old now though.
22" monitor ( play games at 1680 x 1050)
Here is my situation, I would like to update my graphics card, been looking at the radeon hd 5xxx series and liking what i see. I would like to get an HD 5850. However I don't know if it will push my psu too close to the max. Using the extreme psu calculator it says I should have 494 W and 33 amps on the 12 v.
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU: AMD Phenom II X4 940 3000 MHz Deneb
CPU Utilization (TDP): 90% TDP
RAM: 2 Sticks DDR2 SDRAM
Video Card 1: ATI Radeon HD 5850
Regular SATA: 2 HDDs
DVD-ROM Drive: 1 Drive
DVD-RW/DVD+RW Drive: 1 Drive
56K PCI Modem: Yes
Sound Blaster - All Models: Yes
USB: 4 Devices
Fans
Regular: 2 Fans 80mm; 2 Fans 92mm; 1 Fan 120mm; 1 Fan 140mm; 1 Fan 250mm;
Keyboard and mouse: Yes
System Load: 90 %
Capacitor Aging (+ W %): 20 %
Recommended Wattage: 494 Watts
Recommended Amperage:
+3.3V +5V +12V
5.6 A 15.7 A 33.1 A
This is at capacitor aging of 20%.
Do you think I am safe with this configuration?
If not, my other options were
Get a hd 5770, which would draw 445 w and 29 amp with the same configuration. Based on the prices I have seen (I am in Canada btw) the5770 is about 50 dollars less than the 5830, and since I only run at 1680 x 1050 it seems like a more reasonable option. I typically upgrade video every two years.
Or I could go 5830 and use the approx $70 difference between the 5850 to invest into a new psu right now.
My preference would be the 5850 as I said earlier, I don't have a lot of money to play around with for this,
If you have any comments suggestions or whatever I would be greatful, thanks
4 gigs Patriot ddr2
evga 8800 gt 512mb
56K PCI Modem: Yes
USB: 4 Devices
Fans
System Load: 90 %
+3.3V +5V +12V
5.6 A 15.7 A 33.1 A
