Elixer
Another interesting read from Backblaze guys http://blog.backblaze.com/2014/05/12/hard-drive-temperature-does-it-matter/#more-5637
I guess, this also explains why most all exernal HDs that come from the makers have no fan.
Which basically means as long as you are within the temp range of whatever they rate the HDs (WD Reds are 0C - 70C!, black, blue, green 0C - 60C, purple 0C - 65C Toshiba 0C-70C, Hitachi 5C - 55C, Seagate (newer), 5C-60C Seagate older, 5C- 50C), you will be fine.Hard Drive Temperature Takeaways
Overall, there is not a correlation between operating temperature and failure rates. The one exception is the Seagate Barracuda 1.5TB drives, which fail slightly more when they run warmer.
As long as you run drives well within their allowed range of operating temperatures, keeping them cooler doesnt matter.
