that drive(D740) comes with a capacity limiting jumper which you need to remove to see the full size of the hdd. look at the bottom of this page to see where the jumper is!
Make sure that your bios can support drives larger than 32Gigs. You might have to flash your bios to the latest one.
There are limitations at 8Gigs, 32Gigs and 137Gigs for certain bios's. I had to flash mine to read my 45Gig IBM drive and it worked fine after that.
I read in the faq section here and at microsofts faq page that this is a common limitation of fat32...I would either partition it into 3 drives or make it an ntfs...
I could be wrong cause I know squat about this other then what I have read trying to solve my winxp hdd recognition problems...
