I installed a used WD 64aa hdd in my system as a slave converted it to fat 32 but the prior user had it set up as 2 drives in win 95 how do I get it back to being 1 drive??
Now you have to create a primary DOS partition and then it will be by default, Active." Then you have to format it and add system files to make it bootable.
