- Jun 30, 2004
- 16,822
- 2,143
- 126
Everyone is familiar with the standard Radio Shack or similar coax splitter, with two or three male fittings on one side of a little metal box, and one or two more of them on the opposite side.
Would there be advantage to connecting two separate HD OTA antennae through a splitter to a single coax connection to the Tablo? The Tablo converts a radio/tv broadcast signal to a LAN-distributed stream for access by PC, HDMI TV, tablet, laptop and/or phone -- by Wi-Fi or twisted-pair Ethernet.
I am located SE from LA and NW from San Diego. I would only guess that the transmitters deployed in LA would be located in the San Gabriels, more N from here than downtown. I live on the crest of a bluff that is about 1,000 feet above sea-level, looking out on a plain toward SD and at a nice height to intercept signals from LA or the mountains. I probably only need one antenna to get it all, but there are stations in San Bernardino and other places.
One good antenna should do fine, but you can get an indoor OTA HD antenna for just over $25, which might be a reasonable extra expense if there's an advantage.
