HD Homerun Prime - $89.99
PokerGuy
13,650
201
101
Who said that? It is still in the win 10 preview builds.
Last I read it was essentially the same WMC from windows 7 that was put into windows 8, with no (or very minor) updates, put into windows 10. As with windows 8, users will no longer get it automatically with windows, you'll have to pay for it separately -- a complete ripoff IMO, and one of the things that really soured me on win 8.
Elixer
10,371
762
No idea if it is a new version or not, I was just saying it still is there.
As for paying for it separately, I think that has always been the case, unless you got the "premium" version of win 7, so, nothing has changed there.
Win 8 had it free for the first few months as well.
Who knows if they will do that again or not.
SimMike2
2,577
Windows Media Center was included with Windows 7 Home Premium, Pro and Ultimate. Those accounted for probably 99% of all Windows 7 copies. So, yes, WMC was free with Windows 7.
Raincity
4,477
12
Now that Silicon Dust has finally released a plugin for Kodi https://www.silicondust.com/forum/viewtopic.php?f=87&t=18949. We all have more options if WMC goes bye bye in Windows 10. WMC Sever. Argus, Next PVR will work on the backend with Kodi. The copy once flag is less than an issue now that HBO, Showtime, Cinemax stream their original programming the next day over the internet.
ivwshane
32,517
15,399
lupi
32,539
260
It is rather sad that ms still hasn't said anything official about status of WMC 10.
sep
2,553
Well I feel a lot better now :thumbsup:
SimMike2
2,577
How do you use Kodi? Is it Windows software? Does it let you record and watch protected content like HBO?
ivwshane
32,517
15,399
You can run it as a windows program, as a program for Linux and apple, or even as a standalone OS using openelec.
Unfortunately it does not record (or watch as far as I'm aware), protected content, except in windows media center.
PokerGuy
13,650
201
101
Huh? It was (I believe) included with every version of win 7 other than the "basic" stripped down version intended for sale in "developing countries". That means it was freely available to 99% of windows 7 users without requiring additional purchase.
Yep, I made use of that offer. I wish they would have kept it free.
PokerGuy
13,650
201
101
Ok, that's huge!
Unless I'm just completely missing out on some aspect, it really doesn't change anything. There have been plenty of plugins and other options to allow you to use the HDHR outside of windows media center. I've been using it with Kodi for a while now (even back to xbmc), including the pvr.
You don't need WMC to use the hdhr prime at all. However, the problem is that without windows media center, you can't use the HRHR prime to watch anything that is drm protected. HBO and stuff like that obviously is, but ISP's have the option of flagging pretty much anything as protected. Where I live, every channel other than the local OTA stations are restricted, so unless you use WMC, the hdhr prime is pretty much worthless with the cable card.
With MS appearing to lose interest in WMC as part of their product, I don't see much of a future for cable card or the HD Homerun (and other products like it). I guess with the future of tv moving over to the internet and streaming anyway, it's probably a moot point.
PokerGuy
13,650
201
101
Is there any method to hook up the hd homerun prime to a tv ?
Basically, the HDHR just takes the cable signal, decodes it and streams it over a local network (wired or wireless). In order to use it with a tv, you need to have a device that can grab that stream from the hd homerun and decrypt it and display it on the tv. (so you need an htpc or something similar).
SimMike2
2,577
Installed Kodi and it works good for what it does, which is only live TV, no recording DVRcapability. Still, it is a good start. If MS pulls the plug on WMC, it is a good step.
Elixer
10,371
762
Don't know if people knew this about the Prime or not, but, you don't actually need ANY software to record.
What you do is http://<ip addr of prime>:5004/auto/v2?duration=3600
auto= any tuner (tuner0 or tuner 1 or tuner2 instead of auto to pick that specific tuner), v2 is the virtual channel, and duration is in secs, so 3600 = 1hour.
SimMike2
2,577
Tried the NextPVR and it didn't seem to work for me. But I admit I didn't read up too much on how to set it up. It is just that setting up Kodi was so easy.
The manual record function listed above is nice, but it certainly isn't a full functioning DVR like WMC.
PokerGuy
13,650
201
101
Yeah, setting up the kodi plugin for hdhr is certainly light-years easier than npvr and plugins etc, and it works well.... but only for those channels not drm protected. If you're lucky and your ISP doesn't flag all the channels as protected, that's great. If not (like me), then you're kind of stuck to wmc at this point :(
PokerGuy
13,650
201
101
Interesting, I hadn't seen this before. What does that do exactly, does it save the stream for one hour from that tuner to a local drive or something?
SunnyD
Belgian Waffler
Jan 2, 2001
32,674
145
www.neftastic.com
Keep in mind that this is an MPEG2 stream, so it'll be BIG.
Medikit
338
Where does it save?
Elixer
10,371
762
lupi
32,539
260
Size depends on the broadcasters. I've seen between 3.3 and 8.5 for a single hour recording.
Elixer
10,371
762
Oh, that is true as well, the example I gave was for 1920x1080 content.
If it is 720p then fie sizes go down to 3GB and 480 is ~1.5GB.
