Hello,
I bought a WD 5200 RPM 40 GIG HD today. I also have a WD 13.6 gig 7200 rpm drive. I installed the drive, and the BIOS sees both drives correctly. However, when it's loading windows, the windows screen comes up, then it goes black with a cursor in the upper left, and will not finish loading windows. I copied one drive to the other and tried booting off both of them w/ no luck. I set the 13.6 gig to master and the 40 gig to slave with the 13.6 on the end of the cable and the 40 in the middle. I could get into safe mode windows, but could not boot normal. I then disconned the 40 gig and booted successfully into windows after setting the 13.6 gig jumpers back to "single drive settings." All is apparently well, I did have to reinstall vid drivers though. Anyone know what the deal might be w/ this new HD and why I'm unable to get into windows when both are connected?
System:
WD 40 gig 5400 rpm
Win 98se
VisionTek GeForce2 64mb GTS
Duron 600
Abit KT7
Please give me any sensible suggestions you might have, and let me know if more system info is required.
Thanks,
Otis
System:
WD 40 gig 5400 rpm
Win 98se
Duron 600
Abit KT7
Thanks,
Otis
