Originally posted by: gobucks
i used to have the x-fi from my socket 939 system before i upgraded, and it was a hell of a lot better than AC97 audio. but then i got a conroe system with the gigabyte DS3, and i have to say that the ALC 883 is a HUGE step up from AC97. i had a hard time seeing any improvement with the x-fi, so i sold it. the x-fi might use up slightly less CPU, but the azalia audio doesn't use up a whole lot of the CPU either, so i'd much rather spend the extra cash on a faster video card. after all, $100-130 is the difference between a 7600GT and a X1900XT 256MB, which would net you MUCH more than the x-fi ever could.
save your money. go with the onboard audio right now. if you really don't like it, then buy an x-fi.
Originally posted by: bigboxes
Haha... could you look anymore like your avatar YOyo??
Originally posted by: YOyoYOhowsDAjello
What speakers / headphones are you going to end up using?
If you're using a $150 or less 5.1 system, it probably doesn't make sense to spend ~$80+ on a soundcard. If you're hooking it up to one of the top computer speaker sets, or going into the "real speakers" range, then yeah, it might be a good idea.
If you're doing this for just a performance standpoint vs sound quality, then you might be better off just putting that money towards your videocard budget depending on what you have planned at the moment.
Originally posted by: bamacre
Creative's drivers are enough to keep me satisfied with integrated HD audio.
:thumbsup:
X-Fi is a great card, but few people have the audio components on the other end to really make it shine. Which means waste of money.
