HD 7970ghz still viable?
Anarchist420
8,645
www.facebook.com
9800 Pro and the 5870/50 were amazing cards.
L O L. The 9800 pro straight up sucked mad D because it could only do brilinear, it only had partial precision fragment shaders, and the only z-buffer format was partial precision (which ironically was a mistake nvidia would copy with the Geforce 6/7 series). basically, ATi's transistor budget was biased completely towards performance so it sucked. The Geforce FX would've been good for its time had full precision been full speed rather than half speed, had the drivers not forced trilinear optimization, and if it had used properly rotated grid AA patterns. personally, i think they should've made the AA sample pattern properly rotated grid, dropped the w-buffer support, dropped 24 bit fixed point z-buffers, made full shader precision full speed, and had z-buffer formats D24FS8 and D32 only. the Geforce 6/7 series sucked too. it had rotated grid AA, but that didnt work with 64 bit float ARGB, its shaders couldnt do integers calculations, and it only had partial precision z-buffer which made matters even worse since the w-buffer was removed. so the Geforce 8800 GTX and GTS 640 were the first nvidia products that didnt suck in my opinion and they were actually quite good other than the fact that they didnt work properly with double agent. matrox and 3dfx kicked nvidia and ATi in the ass.
As for the 5870/50, the only good thing I can say about it is that it works better with Splinter Cell Double Agent than nvidia GPUs do.
WhoBeDaPlaya
7,413
401
7970 Ghz edition was one of the only decent products that AMD/ATi ever made.
I've owned the 9600 Pro, 9800 Pro, X800XT, X1900XT, 2600 Pro, 4850, 4870, 4890, 5830, 5850, 5870, 6950, 6970, 7770 and 7970.
All giants pieces of crap, they were :rolleyes:
Sohaltang
854
Your card is only 2 years removed from top of the line. Of course it's still viable!
Yeah how many cards are better today? Especially if you running over 1 GZ and most will easily hit that. 4 or 5 if you toss out titans or dual GPU cards?
R290
R290x
780
780Ti
Then maybe the 280x and 770 and they are not worth to extra cost to upgrade.
AznAnarchy99
14,695
117
English bro.
Makaveli
4,798
1,263
Considering i've owned almost all of the radeon's ever released minus the Dual gpu cards i'm gonna have to disagree with this statement!
*kjm
2,222
Have to agree...
I only play D3 and LOTRO and I still cant justify upgrading my 5870. I did end up upgrading my CPU from a I7 860 to a I7 4770K, increased the ram to 16gb from 8, installed a 480gb SSD and that helped a lot!
Black Octagon
1,410
As others have already said, for PS2 you should OC your CPU (much) further before buying another GPU.
I may have missed it, but are you giving that GPU a manual OC or running the 'stock' OC?
Ventanni
1,432
142
That's a total sidegrade. It's an absolute waste of money to buy a 770 when you have a 7970. Some might even consider that a downgrade.
My reading comprehension skills failed me this time. I didn't read far enough where he stated he already had a 7970. I take fault for that.
MongGrel
38,466
3,067
121
I had a dual GPU 4870X2 for awhile, it was pretty nice also att.
I've owned many on both sides of the fence over time.
n47h4n96
25
Everyones commented without asking what you require your graphics card to perform, you could be playing Chress for all I know. What are you looking to run n your PC? What resolution is your display?
Makaveli
4,798
1,263
The 4870 and that version were great cards and a nice set up from the 3870.
Important question!!!!
Going to assume 1080/1200p which is the sweet spot for this card. You can play most games at ultra settings +/- some aa.
1440p is doable but you will be at High settings and may still require turning down more settings than at the above resolution.
The Cpu driving it also matters!
ocre
1,594
7
Absolutely. viable
Do not buy a GPU now whatever you do!!!!!!!
I think that the landscape will be much more favorable in a few months. Especially when Nvidia and AMD try hard to win over the holiday sales.
If you waited this long, wait a little longer. Its gonna get a lot more interesting, i promise
Madpacket
2,068
326
Doh edit, thanks Techhog..
OP, 7970 crossfire would work fine with 280x but that combination can suffer from microstutter. I think you're possibly CPU limited but you should measure that to be certain before buying a faster card.
Techhog
2,834
I've seen people recommend not buying a 7970 and instead get the 280x lol. Re branding is a killer.
What 7970 do you have? If its a reference design flip over the bios switch and flash it with a 7970 GHZ bios.
That's all I would do.
You should have read the OP before replying.
