HD 7970 PCB Numbers for Reference Cards. All the same so far?
sparkuss
102
I'm still waiting to purchase some HD 7970's until a specific waterblock releases. These blocks from AquaComputer have normally been specific to PCB numbers.
The only PCB number I've seen legible from reviews so far has been 109-C38637-00.
If anyone has noted, have they all been the same across reference cards so far?
dajeepster
1,974
16
i have four different cards at home that i can check ... xfx, powercolor, visiontek, and sapphire... i should be able to check thursday evening... i took pics of them
OVerLoRDI
5,490
4
AquaComputer makes some incredible stuff, but waiting for them really isn't worth it in the realm of water cooling. Assuming AquaComputer's blocks are superior, they probably will only be 1-2C better.
If it is about aesthetics, that is different, their blocks do look sharp.
sparkuss
102
dajeepster,
Thanks for that.
OVerLoRDI,
I like how thin the AC blocks are and they are full metal and hopefully will also release in Nickel. I haven't heard of any plating problems with them compared to others.
Cheers
Stuka87
6,240
2,559
AMD is pretty good about not changing heat sink mounts. It has stayed nearly the same for ages. Its possible an existing water block will work on them.
thilanliyan
12,072
2,280
Not the full cover ones but the the core only blocks likely yes. Heck I have a DD Maze4 acetal block I'm using on my 6950 that I first used on an X1800XL!! :eek:
Stuka87
6,240
2,559
Ahh true. If he is looking at one that hits the ram chips and such, then it would need to be specific.
dajeepster
1,974
16
sorry i took so long... all the part numbers are the same on all my cards... that number right above the PCI-E edge connector.
i have all reference cards
sparkuss
102
Excellent news and many thanks,
Now I can just get the best price without worrying about the PCBs.
Thanks again
