- Mar 14, 2016
- 4
- 0
- 0
Note: I've posted this on other online forums.
I'm about at wit's end. Yesterday I was running Dota 2 and I was getting 55 to 93 fps. Today it's stuck between 28 and 30 fps.
I have HWinfo64 and RivaTuner running with OSD to monitor everything that I think I should (CPU cores' temps and total usage, GPU temp and usage). GPU usage is stuck at 100% with temps around 70*C; total CPU usage hovers around 45%, 55*C temp. I'm not sure why, but it seems this HD 7850 is always at full load even when it isn't doing anything (i.e. even when all settings are dialed down to the lowest, GPU usage is still at 100% and temp at 70*C).
It is worth noting that on any normal day I'd get around 65% to 85% total CPU usage and around 80% GPU usage when running Dota 2. But today everything just looks odd, as CPU usage doesn't exceed 50% but GPU usage is always at 100%
Things I've tried so far:
1. Uninstalled driver, downloaded latest driver (dec 2016) from AMD website and installed it -- no improvement;
2. Used DDU (display driver uninstaller), reinstalled newest driver -- no improvement;
3. Ran Malwarebytes, 0 malware found -- no improvement;
4. Overclocked via AMD overdrive -- no improvement; Reverted to stock speeds, no improvement;
5. Tested other games, there are noticeable framerate drops (e.g. Sleeping Dogs normally stable at 60fps on custom mid-high settings, but today it's stuck at 28fps with occasional spikes to 55fps; GTA V which is normally stable at 60fps on custom mid-high settings ran 30fps today with occasional spikes to mid 40s; Battlefield 4 which normally runs at 60 fps on custom mid-high settings now runs at around 28 with occasional spikes to mid 40s);
6. Ran 3D Mark Firestrike, got a score of 3262 (significantly lower as compared to the score I got when I ran the same test on Feb 19, which is 4241)
7. Went to BIOS, loaded optimal default settings -- no improvement.
8. Verified Dota 2 game cache, no improvement.
9. Uninstalled Dota 2, reinstalled, dialed settings down to lowest -- got around 35fps, a measly 5fps improvement at most, but looks real ugly now -- GPU usage still at 100% while CPU usage still around 45%, per HWinfo64/RivaTuner OSD.
10. Unplugged my second monitor, made sure Windows only detects a single monitor. No go.
11. Did a system restore (restore point March 9 2016) -- no go.
My PC specs:
- AMD Phenom II X4 965 BE cooled with DeepCool Ice Wind Pro (not overclocked);
- HIS HD 7850 1GB GDDR5 256-bit (via PCI-Ex16 slot -- I bought this used in December of '15, it was running perfectly fine until today)
- MSI 770-C45
- Kingston HyperX Fury 4GB DDR3-1600+Geil Value RAM 2GB DDR3-1333 (dual channel mode, default speed 1333mhz, total RAM 6GB )
- Zalman ZM600 HP 600w semi-modular
- Seagate Barracuda 500GB
- Windows 10 Pro 64-bit activated (upgraded activated Windows 7 64 bit in July 2015)
I have a dual monitor setup, both are Samsung SyncMaster S20B300's.
Anyone ever experienced this? If so, did you get to figure out what was wrong? Or do you all think this could be a sign of a dying GPU? Or does AMD just suck so bad? (I used to be an AMD fan, but meh).
My PC specs:
- MSI 770-C45
