- Dec 26, 2007
- 183
- 0
- 0
Win7 x64, Catalyst driver 11.3, also tried 11.4pre.
Have a HD 6950 flashed to 6970. It has been running stable for 3 days.
I was running an GPU intensive program (GPU bitcoin mining). Right AFTER I quit the program, the fan just went FULL BLAST!
Here is what I have tried and my observations thus far:
1. First time this happens is when I QUIT the GPU intensive program. Fan speed went UP when the GPU usage decline from 98% to 1%. The card now sits at 40C.
2. Tried to set the fan speed manually using CCC and MSI AfterBurner, but no luck.
3. Was able to adjust settings before, but now the card just won't take any fan speed adjustments. Adjusting the clock speed still works, but only the fan speed is not working.
4. Since this occurred after I quit the GPU intensive program, so I thought if i start up the program, the fan will go down, but that did not happen.
5. Reboot also didn't work.
6. Reinstalled drivers, didn't work. Tried 11.3 and 11.4pre.
7. Flash the card back to 6950, no luck.
8. The fan speed sometimes drops down to normal when GPU temperature rises to 60C.
This is so strange, why fan speed go down when temperature rises? But this happens only sometimes.
9. Even if the fan speed does go down sometimes, it always jump back up later. Sometimes 1 hr later, sometimes 1 days later. No pattern.
10. Installed new 11.4 official driver
11. Switching BIOS to non-writable position.
After all these tries, still can't slow down the fan!
HELP!
The fan is VERY LOUD, and I can't live like this!
HELP!
