- Sep 26, 2009
- 17
- 0
- 0
CANADIAN.
Your Newegg etc. links are welcome and helpful, but I'll be unable to order from them directly. Will likely use NCIX.com.
CANADIAN.
Use: General gaming. I don't overclock.
Here's what I have right now:
PSU: Antec Earthwatts EA650
CPU: AMD Phenom II X3 720 Processor
Mainboard: Asus M4A785TD-M EVO
Memory: 8GB DDR3
Video: GeForce 8800 GS
Monitor: Will be upgrading to 24" or larger soon, likely 1920x1080. Will possibly add a second, smaller second monitor later but it will not be used for gaming.
Case: Cooler Master Cavalier 3
Size issues? Current GPU's length is 9 inches. There are no other cards in my mobo, but there's very little additional clearance horizontally. Looks like I could fit a card that's 11" long max.
Power issues? PSU obviously has enough juice, but it's a couple of years old. Anything it's lacking? Has 1 x 6-Pin, 1 x 6+2-Pin PCIe connectors.
I'm building a system for my wife right now, so I thought I'd see what NCIX has on sale:
Powercolor Radeon HD 6870 900MHZ 1GB 4.2GHZ GDDR5 2xDVI 2xMini DP HDMI - $154 ($174 before rebate); 9.5" x 4.38" x 1.5"
XFX Radeon HD 6870 Dual Fan 900MHZ 1GB 4.2GHZ GDDR5 2xDVI HDMI 2x Mini Display Port - $159 ($179 before rebate); 10.3" x 4.4" x 1.5"
There's also a Gigabyte for $160, but it's a whopping 11.42" x 4.96" x 1.50" so unfortunately out of the question.
I don't really have brand loyalty (or knowledge) between Powercolor and XFX. I like that the Powercolor us about an inch shorter, giving some extra breathing room. Other than that, what do you think?
Thanks for your advice!
