hate to bump an old thread, but i thought i'd start here...and if it doesn't garner some responses, i'll ask my question in a new thread.
the simplified question is this:
which Z77 mobos support simultaneous use of the intel HD 4000 iGPU and one or more discrete GPUs? i'm not trying to run multiple monitors using both the iGPU and a dGPU like the OP...rather i would like the HD 4000 iGPU to be a dedicated display GPU and my discrete GPUs dedicated crunchers. that way neither of my dGPUs have to allocate any resources to running the display and i can avoid GUI lag altogether. long story short, i recently purchased an i7 3770K and a Gigabyte Z77X-UD4H mobo, and it turns out that this board won't allow me to use the iGPU and any dGPUs simultaneously. from what i gather online, particularly in
THIS THREAD in Tom's Hardware forum, only certain Z77 mobos support simultaneous use of the iGPU and dGPUs, and it is typically a "multi-monitor" setting found in the BIOS that enables it. my mobo's BIOS does have an option to enable the iGPU, as well as an option to select the display interface (IGFX/PCIe/PCI/etc)...but there is no option to enable multiple-monitor setups using the iGPU. you'll note in the thread i linked that someone has an "iGPU multi-monitor" setting in his/her ASUS P8Z77-V PRO mobo's BIOS that allowed him/her to do a multi-monitor setup using the iGPU and dGPUs (or more importantly, allowed him/her to use the iGPU and dGPU(s) simultaneously, regardless of whether they were to run multiple displays or not)...so obviously the ASUS P8Z77-V PRO is one such mobo that allows simultaneous use of intel iGPUs and dGPUs, but what are some others?
TIA,
Eric
