HBM For Carrizo?
Erenhardt
3,251
105
101
With what, a 200W TDP? The APUs already throttle as it is.
#12
Also, 7850 and 7870 are 100 watts and less:
With lower voltage they could decrease it even more. Cut some for 256bit 2 BG GDDR5 memory and it doesn't look too bad for an APU. Its soon 3 years after the pitcairn release. They surely improved much upon that.
140W TDP is not something special for a motherboard - the old phenom CPUs were 140Watts.
Enigmoid
2,907
31
Spawne32
230
My 7870ghz edition was rated at 175w TDP max, and 10w at idle, that was on the box itself.
geoxile
327
25
Reagrdless if you like it or not those are the official TDP numbers.
Power numbers are under gaming load. They may be significantly higher under compute.
Under heavier loads the 7870 is generally around 125-130W. Lower than TDP but significantly higher than any APU to date.
http://www.guru3d.com/articles_pages/amd_radeon_hd_7850_and_7870_review,7.html
Stick on a quad CPU and you are looking at at least another 60-85W.
The 7870 is also clocked at 1Ghz, while the best iGPU (the 7850k's iGPU) is only clocked at 720mhz. Plus the 7850k has its own off-die memory (GDDR5) structure whereas on an APU it would be sharing memory with the CPU.
Erenhardt
3,251
105
101
sure. I can OC my 7870 to 1250 MHz with 1.3Volts and +20% power and it will draw around its TDP.
But it can be set to -20% power limit with lowered voltage and go well below 100 Watts
7870 may have 175W TDP, but that doesn't mean it can't be configured to run on lower TDP. In fact Pitcairn is a a mobile 7970m with 100 W TDP:
http://www.notebookcheck.net/AMD-Radeon-HD-7970M.72675.0.html
You don't need 4M/8T Excavator in APU. 4 threads@3.5 GHz will do. That should be more than 50 Watts, which leaves 90 Watts for IGP.
Not to mention that the thermal/power margin can be shared and shifted accordingly to task needs (improved amd kaveri APM).
System like that would blow past the most PC my relatives/ friends use for gaming.
ShintaiDK
20,378
145
monstercameron
3,818
The 2 products you compare doesnt run at the same speed. Also one cost significantly more than the other.
If you wish to get the absolute best bins for your APU dream. Then price will follow up.
Premium price for premium performance or does that only work for others?
Paul98
3,732
199
I would suggest looking at the m295x to get a better idea of what might be possible with a smaller version of that in an APU.
Enigmoid
2,907
31
M295X is a 125W chip (using notebookcheck).
That die is already ~360 mm^2. Add 2 modules, uncore and cache and you are easily over 450 mm^2, HBM or not.
If only 5-10% of your entire bins that hit those targets....
Yep, and compounding that is the fact that that many shaders is simply unfeasible in most notebooks meaning that AMD would have to make at least two dies. (Its unfeasible to deactivate that much to get it in a 35-45W tdp window).
Paul98
3,732
199
LOL, we are talking about a similar chip with far fewer SPs. Before we were just talking about 7850/7870 taking over 100 watts. Talking about something similar but smaller that would go well in a APU.
Enigmoid
2,907
31
Yes and you are picking mobile dgpus which are the best binned of the lot. Unfortunately when you put graphics cores in an APU you don't get to pick and choose the better bins. M295X is a huge chip that consumes 125W and is overheating in the imac (105C).
My point still stands. A 7870 (1280 shaders) is over 200 mm^2 on 28nm. Sticking 2 modules, uncore, cache, and other features such as true audio will easily be another 100+ mm^2. The end result? A taheti sized chip that must be sold for a taheti like price and is too power hungry to fit in mobile.
krumme
5,956
1,595
And? It will be a balanced setup for desktop and with far lower total cost than comparable solutions. I dont think they will do it. But the market is there. Its where the majority of discrete cards are sold meaning there is a need and a willingness to pay for that need.
Paul98
3,732
199
there is so much wrong with this post I am not going to bother.
Aug 11, 2008
10,451
642
Even if the performance can somehow reach 7870 levels in an APU (which I seriously doubt for a long time if ever) I would still prefer a discrete card in a desktop, because you can upgrade it without replacing the cpu as well. With gpus progressing still faster than cpus I would much rather not have them tied together, since a gpu upgrade is much more likely than a cpu.
monstercameron
3,818
Seems like an arbitrary decision, why not get a cpu and gpu upgrade at the same time?
NostaSeronx
3,701
1,230
@ShintaiDK, The software might be reading "GPU" space and interface size.
2 GB HBM / 2048-bit
1 x 1024-bit -> CPU space // 1 GB
1 x 1024-bit -> GPU space // 1 GB
Hence, the reported 1 GB with 2048-bit space. Since, it is only reporting the GPU side.
The point of HBM is not solely for graphics. It is for lower latency and higher realistic bandwidth. There is a reason why SK Hynix has said networking is the biggest design win area.
