Hayabusa engine in a MK1 VW?
Status
Not open for further replies.
Greenman
22,345
6,490
I wouldn't have thought a Busa motor would produce enough torque for use in a car.
halik
25,696
There is a huge issue with oil deprivation on these conversion - bikes lean it during cornering, so the pickup is always submerged in old. When you shove it into a regular car, the oil pans aren't deep enough to keep the pickup in oil during lateral acceleration - people spin bearings like no other on autox and such.
Greenman
22,345
6,490
That makes no sense at all. Wouldn't the same thing happen going down a long straight stretch of road? And even if such a thing could occur, wouldn't it be easy enough to add an oil pan spacer and increase the volume?
Understand that I have no knowledge on the subject, I'm just guessing based on what seems logical.
halik
25,696
I'm pretty sure you can't pull anywhere near as much Gs under acceleration or braking compared to ~1G in lateral turns, plus the engine is mounted transverse, so the oil has less distance to displace back-and-fort as opposed to side to side.
And yeah the trick is to get a deeper pan and extend the pickup way down... lots of custom fabbing.
ballmode
10,246
He speaks truth...
usually when you brake you aren't running the engine at high RPM's, you clutch in and basically slow down.
MovingTarget
9,002
115
Well, a Haybusa-powered Geo Metro won a recent LeMons race....
:D
jagec
24,442
Originally posted by: DivideBYZero
Are you kidding? It's easier to pull G's braking than turning.
Yeah, but bikes brake too, so the engine can deal with that.
That 'busa motor finds its way into everything. I have to wonder how many people add the turbocharger for the >500 hp...I'm sure it's terrible for reliability, but if you're shoving a motorcycle engine into a car you obviously don't really care much about that.
Status
