Having trouble finding a tv stand or entertainment center that will fit my mini fridge in my theater room
Dezegle
I see it’s been a while since you posted, but I just wanted to ask—did you ever find a setup that worked for both the mini fridge and your gear? I’ve been thinking of adding a fridge to my own space and was curious how yours worked out. Have you looked into kitchen islands or bar carts? Some of them might offer the width and storage you're looking for.
Reactions: Simmvest
Simmvest
I ended up repurposing my Savanna 6 drawers dresser for my setup. I took out the drawers on the right side and reinforced the frame to fit my mini fridge inside, and it still has space for my game consoles and accessories. The dresser’s height worked out well with my TV once mounted above. It looks clean and doesn’t scream “makeshift.”
RossMAN
Grand Nagus
Feb 24, 2000
79,082
456
Welcome to the forums, you're the 9th active member in the past month.
On a serious note the OP is busy working his dream job, so it may be a while before they reply.
