Subject says it all. My CPU keeps on overheating (according to "ASUS Probe" under windows. I can only imagine what my temp gets up to in Linux.
Specs:
ASUS P3v4x w/P3 733 Slot 1 CPU
2 sticks Mushkin rev 1.5 = 256mb
Voodoo 3 3500 TV vid card
IBM 7200 30 gb hdd
All slots full of cards:
DVD decoder
sound card
network card
modem
Running this all in an Antec 1030B case with 4 big ole fans pointed the correct way (bottom air in, top air out), the hard drive fan in place, a 2coolpc Plus and a Card Cooler XT. Cooling the CPU is a stock cpu fan with some copper cooling grease, but I have had the Alpha P125 with the copper baseplate on there as well, and the Alpha seemed to defy the laws of physics and made the CPU heat up faster. This is of course, all according to the temp sender unit in the CPU slot. The rest of the case never peaks 20C, while the CPU can go as high as 105C while running Norton Antivirus, or some other such high CPU usage program.
ANY help would be appreciated.
Brendan
:Q
Specs:
IBM 7200 30 gb hdd
DVD decoder
sound card
network card
modem
Brendan
:Q
