This is really no different than what guys with 'hobby' cars do all the time. You'll see big cammed/supercharged cars running around with MT E.T. Streets which is pretty much as close to a straight slick that you can run on the road, legally anyway. Although this is only on the rear (wheel, typically anyway), you'll never see these guys running these cars around in the rain for good reason. How much water do you think
this is going to push out from under the tread when the roads are wet? I've daily driven cars on them in the past when their was no rain in the forecast. However, they're drag tires so the sidewall is made to squat to increase the footprint on acceleration so they're a bit squirrely in turns and not suggested for highway/extended high speeds.
That said, I'd guess your looking for something more balanced for all four wheels and all around driving. I'm not aware of any DOT legal slick for that application. High performance radials are going to be your best bet and minimize the groves. If your going all out look for a soft compound tire for the best traction, but expect the treadwear to suffer. Surely if a high performance radial is good enough for a Ferrari, Lambo, Porsche etc it should suit you just fine. If not, I want to see pics of the vehicle they're going on.
