1.In Windows ME it shows me having 3 floppy drives, when i actaully only have 1 which is an LS120 drive, under Win 2K all it sees is the LS120. I also have a ZIP 250 if that makes a differance. How do i fix this. Also while in my computer when i try to click on one of the drives to get info it runs very slow and may even freeze, other then that the computer runs fine.
2.When I turn on my computer it does not check for a floppy in the LS 120, it used to, but i'm nto sure what i did. If i put a system disk in it, it still boots to the hard drive. If it is a non system disk, you usually get that error telling you to take it out and hit any key, i don't get that either, whats wrong.
3.Finally, I have 2 Maxtor 30 gig in a raid array, I also have a Western digital in my computer. I recently tried to use partition magic 6.0 to repartition the WD into one partition, but when I open PM6.0 it only recognizes 2 disks. One disk is the Raid array, the other disk it says is bad for some reason. The problem is that niether of those two disks is my WD from what i can tell. How can I fix these problems.
