Having problems with small business network need ideas/help.
zjbooks
19
I volunteer network help at a education facility about once a week. Anyways, I come in today and find out that several computers on their network have problems saving/printing/opening Word documents and have random Outlook Express messages popping up at startup. Additionally they cannot (from any computer) send attachments.
The Network setup:
-The computers are all running Windows 98 except the server which has NT 4.0.
-The network consists of about 16 pc's and one file server.
-All ip addresses are set up by dhcp.
-Most computers have 64mb RAM and are Pentium II's
The Problems:
1. In Word the user cannot print/save or open a document. The exact error message Word is giving is "insufficient memory to complete this task" even with only systray and explorer in the task list.
2. Outlook express emails are popping up in the start > programs > startup folder, if deleted or moved out of the folder, another message pops back in it's place next time the computer is started. This results in Express (not our default email client) being loaded everytime the computer starts.
3. No attachments can be sent over email. Email server is provided thru ISP---I'm not sure if it might be their problem. They also seem to be having problems opening some webpages, but this is very much a secondary concern at this time.
Anyone have an idea what the problem might be? I pretty much just got here and they're having severe productivity problems.
JERR
348
Have you checked for virusus?
Is Word network install or local?
Is this peer to peer network or NT Domain?
zjbooks
19
To answer your questions
I'm checking for virus's right now from trendmicro.com (it's been going on for quite a while). In particular I'm concerned about "load.exe" it says is infected with Nimda (I thought nimda wasn't infecting Win 98 machines). What exactly does "load.exe"
Office is running locally on each computer.
Yes they are running a domain.
JERR
348
NIMDA
could be Nimda causing all your problems. load.exe is part of virus, the virus will also overwrite various important files so it could be pretty messy trying to remove it.
optimistic
3,006
Solution for #2
Go to START > RUN
type "msconfig" Go to STARTUP tab
Uncheck Outlook Express
*sorry if this doesn't help:eek:
DAM
6,102
man if youre infected with nimba, you are so SOL, go to symantec and try our their clean up tools, this virus is supposed to be pretty nasty, hell i heard it can even mess up your hp printers on the network, and i think any OS is affecting (ofcourse not Linux or Mac :--)
dam()
