I've got something causing problems with this combo but I don't know what.
-hardware
MSI Pro2A (6380) - recently replaced a non-booting AK31
AMD XP 1800+
512MB Kingston DDR (2 sticks of 256)
SBLive! 5.1 OEM (SB0102)
Leadtek Ti200 GF3
Linksys NIC
Enermax case with 330W PS
whopping CPU cooler
various periferals - Logitech wireless keyboard/mouse/steering wheel, HP all-in-one fax/copier/etc., USB hub.
-software
Windows ME
Via 4.37 drivers
DirectX 8.1
Detonator 23.11 drivers
Liveware 3.0
-the problem
Occasional hang during boot, the system sits with a blank screen after the OS loading screen disappears
Frequent crashes during games, in particular UT and RTCW. Crashes are usually an error window that says "this program has performed an illegal operation and will be shut down" but also have been total system lockups and occasionally a dump back to the desktop with no explanantion.
Other than those two things, the system is stable. No problems with IE, Nero, etc. It seems like a problem with the video card. I set all the conservative settings in the BIOS, disabling all the fancy AGP features and bumping the mode down to 2X. It got better but it's not fixed. I have the memory settings set to SPD but I'm ready to start bumping up the timings.
The biggest problem is that I built this for a friend so I don't have it here in front of me. I tested it here at my house when I built it and it seemed fine but once I took it over to his house it has been a big P.O.S. Now he's started talking trash about AMD and my abilities so I'd really like to solve this problem ASAP. Tonight he said he wanted to have me return all the parts so he could go buy a Dell!
I really don't know the root of these problems. Is it a bad video card? Is it Windows ME? It seems like I've seen other people around here with the same problem and most of the time the new VIA drivers fix it, but not in my case.
Where do you guys think I should go next?
I was going to try the AGP driver from Leadtek rather than the new one currently installed.
I was going to bump up the memory timings.
If that doesn't work I was going to take out one stick of RAM in case I got a bad stick.
If that doesn't work I was try and talk him into upgrading to Windows2000 or WindowsXP Pro.
-hardware
AMD XP 1800+
Leadtek Ti200 GF3
Linksys NIC
whopping CPU cooler
-software
Windows ME
Via 4.37 drivers
DirectX 8.1
Liveware 3.0
-the problem
