ClownShoes16
I just got an Athlon 4400+ and it is running extremely hot. I have it on an ASUS A8N-SLI Premium, and also have a 7800 GTX and 2 Gigs of Kingston HyperX. I have it in a Lian Li PC-V1100 case, and I replaced the 120mm intake fan, and 120mm exhaust fan with 120mm nexus fans. They move 36.87 CFM of air each. The case only has one intake and one exhaust. I also have a nexus 120mm fan on a thermalright xp-120 heatsink which I'm using to cool the processor. The processor idles at about 40 degrees celsius, and after running two instances of prime95 for 6 hours, one on each core, it got up to 63 degrees celsius. The other night when I played battlefield 2 for a few hours it got up to 78 degrees celsius. The system runs perfectly fine despite all of this. When the processor temp was at 78 battlefield was still running smooth as glass with all settings on max. I tried taking the heatsink off and reapplying the arctic silver 5 and that didn't do anything. Does anybody have any ideas of why my processor is running so hot? Most of the people in the forums are saying they overclock their 4400+ to 2.6GHz+ and it never goes above 45 under load. Mine is running at stock speeds. Could the processor be faulty, or the temp readings be off? Any help would be greatly appreciated. Thanks
