The system
ASUS Cd-S500/a (ide)
Yamaha CRW8424S (scsi)
Zip 250 internal (ide)
Diamond fusion 16meg agp
Samsung 8.4 gig hd (ide)
realtek RTL8029 nic
Tekram DC-390F/U pci scsi adapter
AWE64 sound card
Shuttle HOT-591p mobo
256mb pc-100 ram
AMD K-6II 500Mhz
The problem I am having is that when making a cd it keeps spitting them out with an error that says it is either another program accessing the drive or the power is being turned off. It worked fine for months with absolutely no problem then last week it started giving me multiple errors. I upgraded the firmware on the burner and the problem went away. Now it is just giving the one error. I have made sure everything is shut down even checked wintop to be sure. As far as I can tell it is not losing power. Any help would be greatly appreciated. The stack of coasters is now up to 9 after close to 70 with no problem at all.
EDIT--> I have also reinstalled ez-cd creator with no change.
realtek RTL8029 nic
AWE64 sound card
256mb pc-100 ram
AMD K-6II 500Mhz
