- Jul 11, 2001
- 41,361
- 10,480
- 136
I never had a problem before with my Pioneer 106s slot loading DVD playing drive but tonight I can't watch movies. I tried playing a music CD and it seems OK for that. I was watching a new movie and it errored. I tried to play it again and it errored at the exact same spot. The message is that the disc may be dirty or scratched:
_______________________________________
DVD Error
Error Code: 89020003
The DVD disc might have been damaged so as to inhibit playback operation.
Close
Detailed
If you hit "Detailed" it says: Please clean the surface of the disc if possible. If it has been scratched, it might not be readable.
The disc looks fine, so I played a few other DVDs (some known good) and also got errors. Some won't play at all. Generally I get this error when I first insert the disc:
Program Error
Autoplay.exe has generated errors and will be closed by Windows. You will need to restart the program.
An error log is being created.
OK
________________________________________
What does it mean when it says an error log is being created? Where do you look for the error log?
I rebooted, same problem. I generally use Power DVD 3.0. I tried playing a known good DVD movie with NVDVD that came with my video card. It at least plays, but every few seconds the scenes just skip forward to the middle of another scene!!! This is the Baby Rigzilla computer in my sig. Any ideas? Thanks!
DVD Error
Close
Detailed
Program Error
OK
