I'm not sure how widespread this problem is but I notice many users get a freeze at sata_nv like I did when installing Mandriva/other Linuxes. I've found a very easy solution: go in to your BIOS, and disable APIC. Then install normally (no kernel arguments (like nolapic noapic acpi=off) needed). Just thought I'd let everybody know. It seems like a lot of people must have nForce 4 + SATA on these forums especially with all the gamers.
This was my problematic config:
A8N-SLI Deluxe (nForce 4 SLI)
2x250GB SATA hard drives on nF4 SATA controller ports 1&2
The options I changed:
-Enabled NVRAID even though I'm not using it
-Enabled Silicon Image controller even though I'm not using it
-Disabled APIC
That's what made it work for me. I'm not sure if the NVRAID and Sil3114 enabling had anything to do with it. APIC is probably what did it (also for another user on a German forum).
-Disabled APIC
