my network consists of a linksys wireless router...a computer directly connected to it via cat 5...and a d-link di-604 wired router...on the wired router is my x-box...ps2 and pc...and the router is connected with a wireless bridge to communicate with the wireless router...both routers are x-box live compatible...
so anyways I turn it on...and connect...I try to join a game it then says it can't connect with x-box live so I launch the troubleshooter...it goes though...cables connected...dns found and so on...but it fails the last test (doesn't say whawt it is)...and just says can't connect to x-box live...so I disconnect the x-box from the router and hook it up directly to the wireless bridge...after that it works fine...so obviously the problem lies with the d-link router...all other online games work fine (pc games and ps2 games)...got the latest firmware...but not sure what to do after that...
