Having problem setting up new seti machine
cakin
1,060
I have to setup at least one machine in my garage with windows in order to take advantage of wireless USB that I already have, everything else out there will be linux.
I purchased OEM license keys (so I would have a few spare licenses - just in case I needed them) They came with the WinME start guide, and COA. The dealer is reputable. The problem is when I try and use the key during an installation. I aleady have 3 installs of winme at home and when I try an install using one of those CD's with the OEM key, the OEM key is rejected. Am I doing something wrong? Is there a command line option I need to use to make the OEM key work?
CADsortaGUY
25,162
www.ShawCAD.com
I'm probably wrong but ....
Anytime I've dealt with OEM software keys - you have to have oem install disks for them to work. It really sucks:|
Hope you get it working - sorry I can't help.:eek:
CkG
cakin
1,060
Fixed it, now I know why the Dr has bi-focals coming in for me on Monday.
the KX combination in the middle of the key looked like KK to me.
Fat finger strikes again!
steell
1,569
Have had the same problem myself :D
