Having PC troubles..need help please!
VigilanteCS
415
Hi,
This tuesday I came home from school, but when i went to turn on my pc, it wouldnt at all. I nelt down behind the pc and the psu was making a nasty "sssssssss" sound, and it smelled a little bit like it was burning. So I did the logical thing and ordered a new PSU, which should be here tomorrow.
My problem is this, when I unplug the psu from my motherboard the "sss" sound stops, and itll start again as soon as I plug it back in. Also, this psu will boot my brothers celeron 766 compaq pos pc. I'm worried that a part other than my psu is defected, like my motherboard. The specs of my computer are as follows:
MSI K8N Neo Platinum
AMD Athlon 64 3000+ 754
512 mb kingstong hyperX
Radeon 9600 pro
80 gig IDE hdd
350 watt Codegen psu (420 thermaltake on the way)
Any suggestions about what I should do? If this PSU doesn't fix it I'm going to RMA the motherboard.
Thanks again!
LTC8K6
28,520
1,576
Well, you've done the only logical thing. It sure sounds like the PS went bad. You'll just have to wait and see if the new PS solves the problem.
VigilanteCS
415
yeah it does, but it will boot my brothers pc but not mine. the ironic thing is that I've been talking about replacing it for a while so i could get a better gfx card, then it got jaelous or something and fried.
Kishan
2,580
what specs are your brother's computer to yours? Does his require less, "juice?
VigilanteCS
415
His pcs specs are:
Celeron 766 MHz
128 mb pc100
20 gig hdd
cd rom
So yes, you could say it does
