having issues with ntfs file system
rasczak
Event Type: Error
Event Source: Ntfs
Event Category: Disk
Event ID: 55
Date: 9/1/2006
Time: 4:21:27 PM
User: N/A
Computer: BLACKBOX
Description:
The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume C:.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 02 00 4e 00 ......N.
0008: 02 00 00 00 37 00 04 c0 ....7..À
0010: 00 00 00 00 32 00 00 c0 ....2..À
0018: 40 00 00 00 00 00 00 00 @.......
0020: 00 00 00 00 00 00 00 00 ........
I've run the chkdsk utility several times already and each time, after trying to delete numerous corrupt files, at the very end it says an error occurs and then throws my into windows.
When I try to get any information from my application logs in event viewer, it says my event logs are corrupt and will not allow me to look at them. The most I could get was this:
Event Type: Error
Event Source: ESENT
Event Category: Logging/Recovery
Event ID: 465
Date: 9/1/2006
Time: 2:44:08 PM
User: N/A
Computer: BLACKBOX
Description:
wuauclt (3576) Corruption was detected during soft recovery in logfile C:\windows\SoftwareDistribution\DataStore\Logs\edb.log. The failing checksum record is located at position END. Data not matching the log-file fill pattern first appeared in sector 188 (0x000000BC). This logfile has been damaged and is unusable.
and this:
Event Type: Error
Event Source: ESENT
Event ID: 439
Date: 9/1/2006
Time: 2:43:57 PM
User: N/A
Computer: BLACKBOX
Description:
Catalog Database (1196) Unable to write a shadowed header for file C:\windows\system32\CatRoot2\tmp.edb. Error -1022.
and lastly:
Event Type: Error
Event Source: ESENT
Event Category: General
Event ID: 490
Date: 9/1/2006
Time: 2:43:57 PM
User: N/A
Computer: BLACKBOX
Description:
svchost (1196) An attempt to open the file "C:\windows\system32\CatRoot2\tmp.edb" for read / write access failed with system error 1392 (0x00000570): "The file or directory is corrupted and unreadable. ". The open file operation will fail with error -1022 (0xfffffc02).
I've started backing up again just incase.
any ideas on correcting this issue? Or is a reformat in order?
System specs:
Windows XP Pro
Athlon64 3200+ (not Oc'd)
MSI K8N Neo2 Platinum
2 wd 36gb raptors in raid 1 (OS which btw I had to rebuild the array for once today)
2 wd 80gb sata drives raid 1 (applications this also seems to have corruption issues and everytime I rebooted windows would do a chkdsk)
AIW ati x800xt
400 enermax PSU
couple of system fans.
It's most likely a hardware issue, filesystems don't just corrupt themselves (ok sometimes they do, but those cases are extremely rare).
